EAGLE User Support (English) Via stitching?
  • Views 2144 views
Via stitching?
I'm designing a 2 layer RF board and I'd like to stitch the two ground planes together with many vias.  Any thoughts on how to do this?
Do I have to do this completely by hand?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    I tried the above .ulp and well, it didn't work for me.  I ended up doing it by hand.  It's an interesting problem in applied computational geometry and I invite others to take up the task.
    this?
    Hi Mark
    There is a ULP you can download named "via-fill.ulp"
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/via-fill.ulp
    You may need to place vias manually. If so set yourself up so that the via
    parameters are set up and the via signal name is pre-named, then you only
    need click the  placement points.
    HTH
    Warren
    news.cadsoft.de
