EAGLE User Support (English) Solder mask for BGA
  • Subscribers 187 subscribers
  • Views 731 views
Solder mask for BGA
BGA solder-ball land pads can be solder mask defined (SMD) or non-solder
mask defined (NMSD). SMD the mask is smaller than the pad, NSMD the mask
is larger than the pad. On a board with several different parts, it is
necessary to have different solder masks.
How can I do this? In the library package definition for each part, I
can only turn the mask on and off.
In the layout, I only have access to the global DRC, which affects all
parts.
Is there a workaround?
Dave
    Richard Hammerl wrote:
    non-solder mask defined (NMSD). SMD the mask is smaller than the pad,
    NSMD the mask is larger than the pad. On a board with several
    different parts, it is necessary to have different solder masks.
    parts.
    Dave
    Switch off the automatic solder stop mask generation in the
    library and draw the mask with the CIRCLE command (width = 0)
    as wanted in layer 29, tStop.
    Maybe let it automatically generate the small ones, and draw only thoose
    you want bigger?
  • Richard_H
    Richard_H over 18 years ago
    parts.
    Dave
    Richard Hammerl
