EAGLE User Support (English) Eagle on Linux display rendering problem
  • Subscribers 177 subscribers
  • Views 576 views
I'm trying to install Eagle 5.1 on Ubuntu Linux 8.04. I have tried to
intall it using apt-get (from ubuntu repository) and by executing .run
file downloaded from Cadsoft. When I install / rul eagle, I get screen
like the one in the screen-shot (attached and url below)
http://cid-9fef434780b4a471.spaces.live.com/photos/cns!9FEF434780B4A471!138/
My laptop has ATI Rage Mobility 128 graphics and am running 1024x768
resolution.
What could possibly be wrong? All the other linux apps work fine.
Chetan Bhargava
    Looks like it was the display depth problem. My default color depth was
    24 bit, it worked when I changed to 16 bit.
    Now the question is whether eagle supports 24 bit display on Linux?
    Thanks.
    Chetan Bhargava
    Chetan Bhargava wrote:
    resolution.
    Chetan Bhargava
    On Sat, 2 Aug 2008 Chetan Bhargava wrote saying :
    Yes, it does. In fact I strongly suspect Eagle cares not one jot about
    colour depth - it leaves all that to the Qt library which in turn leaves
    it to X. I have run Eagle on Gentoo Linux at 24-bit colour for years.
    Looks like you have a problem with your Ubuntu X install, or just
    possibly with your hardware.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Thanks for the info Robert. Maybe my hardware is old; it is Dell
    Latitude C600. My X configuration works on 24 bit as all the apps work
    except eagle.
    BTW, my setup is gnome based so it does not use qt.
    Chetan
    On Sun, 3 Aug 2008 Chetan Bhargava wrote saying :
    That's irrelevant. Whether you use KDE or Gnome (or icewm or xfce or
    qvwm or...) as your desktop does not affect whether a given application
    uses Qt or GTK. A GTK app still uses GTK on KDE, just as a Qt app still
    uses Qt on Gnome. Eagle is a Qt app.
    believe a word.      |
    Looks like only qt related package installed is libqthreads-12
    chetan@latitude:~$ dpkg -l |grep -i qt
    ii  libqthreads-12                             1.6.8-6ubuntu1
                     QuickThreads library for Guile
    Chetan
    Or maybe eagle is using qt libraries from its own package and not from
    the OS.
    In that case when qt delivers streams to X it does not interpret properly.
    Chetan
