EAGLE User Support (English) Problem, drawing a net or wire?
  • Views 488 views
When drawing a net, or a wire, I click on the left key of the mouse first, then move the mouse, but the net or wire doesn’t show up until I click on the left key again. Please help me to fix this problem. The "Bus" command works fine.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 07.03.2012 16:41, schrieb Xiang Zhan:
    I'm using Version 6.1.0. I did in this way: first, leftclick the button (of cause, released after click) to start a net, or a wire, then move the mouse to a destination and leftclick again to end the net, or wire. My problem is that the net/wire does not show up between the two clicks. "Net", "Wire", "Circle", "Arc", "Junction".... all of them have same problem.
    THAT is a problem I don't have a solution for image . But one advice,
    update to version 6.1.2 beta. This has fixed a lot of errors.
    Joern Paschedag
    Am 01.03.2012 00:59, schrieb Warren Brayshaw:
    >> first, then move the mouse, but the net or wire doesn't show up until
    Which version of Eagle are you using?
    I suppose you keep the mouse button depressed. Leftclick and release the
    button to start. While you just move the  mouse clicking the right
    button changes the angle of bends for net/wire.
    Joern Paschedag
    news.cadsoft.de
