EAGLE User Support (English) Move board layout to coord  (0,0)
  • Subscribers 186 subscribers
  • Views 825 views
I started to place components on a layout board, and in the end,
I ended with a 2"x2" board, but the lower left corner isn't at
coord (0,0) anymore. Is there a simple way to move the complete
board (components, wires, outline) to coord (0,0)? Still using
4.16r2.
Greetings,
J. op den Brouw
    Thanks, it worked!
    Jesse
    4.16r2.
    Yes.
    Activate all layers, select the whole PCB, right click in the
    lower-left outline corner and move on (0 0).
    This works if that corner is still on the current grid. Otherwise, you
    should move that corner (you know its coordinate through the INFO
    command) to (0 0) using the '>' symbol that tells EAGLE to simulate
    right-click.
    Bye
    Marco / iw2nzm
    4.16r2.
    Yes.
    right-click.
    Bye
    Marco / iw2nzm
