EAGLE User Support (English) library creation-4 pins on the same signal
  • Subscribers 189 subscribers
  • Views 523 views
nico0481
nico0481 over 14 years ago
I'm trying to make component like :http://docs-europe.electrocomponents.com/webdocs/09d4/0900766b809d4828.pdf on the last page.
It's a screw terminal for an antenna.
In the component creation, I place 4 pads, but each pad is connected to the same signal (antenna).
When I try to link symbol to package in the new library, I've 1 pin on the symbol and 4 pin on the package to connect.
How to connect those 4 pads to only 1 pin?
If I try to rename pads with the same name, erroe is displayed.
Thank you
Regards
Nico
    0 e14 Contributor over 14 years ago in reply to nico0481
    nico0481 wrote:
    >Version is 5.11
    >It's what i've done, but is it possible to draw only 1 pins on symbol (ie an antenna) but package has 4 pads with the same signal
    5.11 can't, but 6.x will do
    Lorenz
    PS: sorry for the incomplete quoting, but I was't in the mood to
    fixing nicos messed-up post.
  • nico0481
    0 nico0481 over 14 years ago in reply to e14 Contributor
    Invité enregistré:
    Am 06.03.2012 11:46, schrieb nicolas toldo:
    Thank you
    Regards
    Nico
    You didn't mention your Version. So give the symbol 4 pins and name them
    name@1 to name@4, then connect the 4 pins to the 4 pads image
    Joern Paschedag
    Version is 5.11
    It's what i've done, but is it possible to draw only 1 pins on symbol (ie an antenna) but package has 4 pads with the same signal see page 5 of previous link.It's the PCB mounting terminal
    Thank you
    Regards
    Nico
    Thank you
    Regards
    Nico
    Joern Paschedag
