EAGLE User Support (English) Question about ULP
  • Views 372 views
Question about ULP
I try to do an ULP for placment on PCB. I have three channel of analog input (audio) and I name them X Y and Z. These three channels are similar.
I would like place manually only channel X and run an ULP for automatic placment of channel Y and channel Z.
My problem is I don't understand how I can in an ULP, I can read position (x y) of a part in channel X and create offsets for channel Y and Z
Someone have an idea??
Example:
RX1: X = 250 mils Y = 100 mils
the result should be for an y offset of 100 mils
RY1: X = 250 mils Y = 200 mils  (Y = Value of X + 1 * y offset)
RZ1: X = 250 mils Y = 300 mils  (Y = Value of X + 2 * y offset)
John Dutoit
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Re: Question about ULP
    >Y and channel Z.
    an ULP can't change board/schematics on it's own, but it can create
    the required script commands, either in form of a script file, or as a
    string that is passed to the exit command
    Lorenz
    OK yet seems me more clear how process, thank you!
    But in an ULP, how can I read the position (x & y) of RX1 and only RX1 (RX1 for my example) and not all parts who are in PCB?
    >Y and channel Z.
    Lorenz
