EAGLE User Support (English) Library update failed (error code 6.1.0-1204). Contact Cadsoft.
  • Views 314 views
  • report_bug
  • error
Hi all,
Whenever I try to replace a part in a schematic, I get this error, followed by "The library update has failed. Your drawing may be seriously damaged. Please revert to a backup.". It doesn't seem to matter which part I try to replace.
I didn't find a place to report bugs apart from this forum, is this the appropriate place to "contact cadsoft"? And is this a known problem with a workaround?
    On 17.03.2012 15:10, Patrik Jonsson wrote:
    Hi all,
    It sounds like a know issue in EAGLE 6.1.0. You could try our current
    beta 6.1.3 where this should be solved. If you are not sure, feel free
    to send your files to support@cadsoft.de
    Richard Hammerl
