EAGLE User Support (English) trouble making part with fine close holes
  • Views 280 views
SouthernAtHeart
SouthernAtHeart over 14 years ago
I'm having trouble making a footprint for this little switch.  The holes are running together.  I can't tell how to fix this.
this is the part:
http://www.e-switch.com/Portals/0/Series_Pdf/TL1290.pdf
This library shows what I've come up with so far.
Any help is appriciated.
...well, it's not let me attach the part I've made...
    Take a 12-gauge shotgun, load it with #9 birdshot, aim at where the
    switch goes, and ...
    Just kidding image
                                                        ... this is
    the part: http://www.e-switch.com/Portals/0/Series_Pdf/TL1290.pdf
    This library shows what I've come up with so far. Any help is
    appriciated. Thanks ..well, it's not let me attach the part I've
    made...
    If you've attached a file it didn't make it. At least not onto the news
    server. Anyhow, I don't really see a problem with this part except that
    the two key holes for the plastic protrusions are interfering with #2
    and #4. Eats into the copper a bit there but I wouldn't worry about it.
    0.053" for those looks a bit much, I'd verify that and als check the
    actual part.
    Soldering that part could leave a stench in the air because the plastic
    is so close.
    Regards, Joerg
