EAGLE User Support (English) dont want pad visible on both top and bottom layer
  • Views 718 views
I have a dual layer board, but i do not want the bottom pads to be visible with the top layer.
The pads are standard all in 1 layer. I can not make a difference between top and bottom layer pads.
I do not want the pads on both layers.
Is there a way to switch some off ?
  • robotonics
    0 robotonics over 14 years ago
    Hi
    You can turn off the pads/vias. You need to click on (select) the display icon in the board editor. Then deselect pads and vias from there. See the pic below.
    Then you can print the top layer seperately. Hope this helps.
