EAGLE User Support (English) Change several pins in symbol with script.
  • Subscribers 190 subscribers
  • Views 490 views
bmoe
bmoe over 14 years ago
Hello.
I need a command that changes several pins in a symbol at once, and in the end I will make a script that automatically do my changes.
I need to change several library symbols, and is going to change width, function and length.
I need commands for:
change width (of a group to) 0,254mm
change function (of a group to) none
change length (of a group to) point
If I in the symbol editor first do a "group all" wich works fine, then "change width 0,254mm" nothing happens to the group, but 0,254mm becomes the default value in the change/with menu.
"change function none" and "change length point" does´nt work eather, but only defines new default values in the menu.
/M
    Matias Sjögren wrote:
    Hello.
    becomes the default value in the change/with menu. "change function
    /M
    You got close. Remember in Eagle the convention is select the command and
    then apply it to the object. This is the reverse of what many are familiar
    with. That of choosing the object and then choosing what to do with them
    So the following says what to do and then what to do it to. In this case its
    to all of the group. The (C>0 0 ) is the equivalent of a right mouse click
    (>) at the board editor origin (0 0) while holding down the CTL key. (C)
    Group all;
    change width 0.254 (C>0 0);
    change function none (C>0 0);
    change length point (C>0 0);
    Warren
    news.cadsoft.de
  • bmoe
    0 bmoe over 14 years ago in reply to robotonics
    I need to do this only with text commands, so no use of the mouse.
  • robotonics
    0 robotonics over 14 years ago
    The only way I know is to repeat your first two steps...
    1. group all
    2. change width 0.254
    and then...
    3. <Right click anywhere on any trace in the group>
    4. <select: change group>
