EAGLE User Support (English) Eagle Stops Working (Crash) Running a Script
  • Subscribers 187 subscribers
  • Views 555 views
aseely
aseely over 14 years ago
I wrote a python script to create an eagle .SCR file which is supposed to create .sym, .pac, and .dev parts of a library for a family of
connectors.
The first device is created correctly,  but as the script starts into the second device when the first "PIN" statement is executed
eagle crashes.  Not sure how to debug this any further.
I cut the script down to the first line on which it crashes on my computer,  which is a Win 7 Pro 32-bit machine w. 2G RAM.
The Eagle version is 6.1.0
My full script is attached (mk_hirose.scr).  The 'mk_hirose8.scr' is a cut-down version which crashes.
If I delete the last line in this mk_hirose8 however,  so stop at the "LAYER" command then it doesn't crash and I can see that
the first device is created correctly.
I am running this by opening a new library  then in the editor running the script from the pull-down menu.
Thanks and Best Regards,
Anthony
Follow-Up:  Haven't had any official replies to this msg.  But upgrade to 6.2 seems to have corrected the issue.
mk_hirose8.zip
mk_hirose.zip
    0 autodeskguest over 14 years ago in reply to autodeskguest
    connectors.
    Anthony
    just tried your scripts with my EAGLE here on Linux. The scripts ran
    well without problems. As soon as my Windows7 computer finished a
    running Autorouter job I will check this there.....
    Both scripts run well on my Windows 7 computer. I did exactly what
    you described........ Do you have further hints?
    Richard Hammerl
    connectors.
    Anthony
    Richard Hammerl
