EAGLE User Support (English) Create Library from Schematic/Layout.
  • Subscribers 189 subscribers
  • Views 1822 views
Is there a way to create a library of the parts from a given schematic/layout?  Or some other solution to my problem described herein.  I have a Schematic/Layout with parts in it that I want to modify, but I do not have the library files to which the parts came from. I am trying to avoid recreating the parts from scratch or replacing the parts from existing libraries in fear of having to redo layout traces.  My hope is there is a script or .ulp that I can run that will recreate said parts into a new library or just let me modify the part.  Any guidance would be appreciated, my search of the internet and forums here yielded no clues.
Eagle Version 5.11.0
    0 e14 Contributor over 14 years ago in reply to robotonics
    Perfect. I think this was exactly what I needed.
  • robotonics
    0 robotonics over 14 years ago
    Hi
    There is ULP available which will let you export all parts from a schematic to a library or multiple libraries. It is called exp-project-lbr.ulp. There is a video here on how to use it.
    Am 13.04.2012 22:11, schrieb Warren Brayshaw:
    >> There is a ULP to do just that.
    >> exp-project-lbr.ulp
    ...and run it from the schematic. In that way you will get the full library
    devices. Running it from the board editor, you only get the packages, if I
    remember correctly.
    Warren
    You do image
    Joern Paschedag
    exp-project-lbr.ulp
    remember correctly.
    Warren
    news.cadsoft.de
    exp-project-lbr.ulp
    Hi Mark,
    Use the exp-project-lbr.ulp that comes with EAGLE. In my experience it
    works best when you let it create multiple libraries vs one library.
    Just my two cents.
    Jorge Garcia
    Cadsoft Support
