EAGLE User Support (English) Eagle 6 lbr conversion?
  • Views 1228 views
I recently had to go back down to Eagle 5, as 6 would constantly crash during layouts and now my custom libraries no longer work in 5. Has 6 done some sort of conversion on them? And if so, does anyone know of a way to get them working back in 5?
    0 autodeskguest over 14 years ago
    Matthew Edwards wrote on Tue, 17 April 2012 06:20
    What cave have you been living in for the last year?  Yes, Eagle 6 uses
    totally different file formats.  In general, new versions can read old
    files, but old versions can't read new files.  Eagle 6 is no different.
    I don't think so.  Just go back to your old libraries.
    Maybe you can export some things to scripts, then run those scripts on
    Eagle 5, but there are probably problems with this.
  • anweid
    0 anweid over 14 years ago
    Am 17.04.2012 12:20, schrieb Matthew Edwards:
    By default, nearly EVERY new version of nearly EVERY software on earth
    changes its file format to adjust for new program features. EAGLE is no
    exception: The file format from version 6 cannot be read back in version
    5 (or from 5 to 4, or 4 to 3, etc.).
    If there are no backups of the old versions, you are in a lot of
    trouble, because EAGLE doesn't support the saving in old file formats.
    With LOTS of work, you can do the following:
      1. With EAGLE 6, export the library as a script file. This script
         file can NOT be read directly with EAGLE 5, because it contains
         functions not available in version 5 (e.g., text alignments).
      2. With a text editor, search for these new functions and throw
         them out of the script file.
      3. In EAGLE 5, create a NEW library and execute the changed script
         file there. If no new functions are available in the script,
         the library (minus thosw new functions) should be reconstructed.
         Save the newly created library under the name of choice.
      4. This needs to be done with ALL relevant libraries separately.
    For convenience, NEVER, EVER, start using ANY new software without
    keeping backups of all the older files - you might need them later on.
    Only after using the new software version for, say, about a year, you
    can think about throwing the old files away. Before EAGLE 5, you could
    use more or less ANY new EAGLE version without problems, because it was
    so extremely correct and stable. Unfortunately, since version 5, the
    update situation is not better than with other software - too bad...
    Andreas Weidner
