EAGLE User Support (English) generate_3d_data.ulp broken in Eagle 6
  • Subscribers 189 subscribers
  • Views 496 views
bvwj
bvwj over 14 years ago
generate_3d_data.ulp uses line widths for 3d component height information.  The ulp code doesn't use u2mm in it's height calculation, so all the component and board heights are off by a factor of 32.  The fix is only two lines of code in the getPartHeight subroutine.  I have verified it works if the u2mm is used and the units are adjusted appropriatly.
Should the downloadable ulp source be fixed?
    0 e14 Contributor over 14 years ago in reply to bvwj
    Barry Walker wrote:
    >V0.8 has the same problem with Eagle 6.
    >lorenznl wrote
    >>I would contact the author of that ULP (out of courtesy) if he is
    >>going to fix it or if he is ok with you uploading the fixed version.
    >>On the other hand, the changes to V0.8 where allready provided by some
    >>other person.
    I didnt't mean to say the bug you reported was fixed in v0.8.
    What I meant is that v0.8 was allready posted by someone other than
    the original author.
    Lorenz
  • bvwj
    0 bvwj over 14 years ago in reply to e14 Contributor
    other person.
    Lorenz
