EAGLE User Support (English) Overlap error with Vias in pad
  • Subscribers 187 subscribers
  • Views 3523 views
  • pad
  • drc
  • vias
I am trying to place vias inside the area of a pad.  The vias are part of the same net as the pad.  When I run DRC, I get an overlap error.  How do I place vias in a pad in a such a way that DRC is happy?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thanks - that setting fixed the problem!
    On 09.05.2012 18:36, Mike Ropers wrote:
    Richard, Thanks for your reply.  Would a "Drill Distance" error show
    up in DRC as just that?  The error I am getting in DRC is "Overlap"
    not "Drill Distance"
    Mike
    If a via that has the same name as the SMD's signal is placed on a
    SMD and there is a clearance value set for "VIA-SMD same signal" DRC
    will report an overlap error.
    Richard Hammerl
    Richard,
    Thanks for your reply.  Would a "Drill Distance" error show up in DRC as just that?  The error I am getting in DRC is "Overlap" not "Drill Distance"
    Mike
    On 06.05.2012 19:33, Mike Ropers wrote:
    From a previous post discussing thermal pads and vias, it looks like the answer to my question is no.
    To confirm, is there no way to add vias to a pad without getting DRC errors?
    http://www.element14.com/community/message/31966#31966/l/re-packages-with-vias-in-smd-pads (/message/31966#31966/l/re-packages-with-vias-in-smd-pads)
    If the via has the same  name as the signal that belongs to the pad
    it is allowed to let them overlap without a DRC overlap error. But
    it could happen that you will get a "Drill Distance" error in case
    the  drills are too close (depending on the Drill/Hole distance
    setting in the Design Rules.
    Richard Hammerl
