EAGLE User Support (English) Disable silkscreen for individual components
  • Subscribers 189 subscribers
  • Views 3295 views
  • librairies
  • silk_screen
I am wondering if there is a way to disable the silkscreen layer on a component by component basis - without modifying the package library.  For example, I want to take a TO-220 package and add a copper area under the tab to provide some limited heatsinking to the PCB.  However, I don't want the silkscreen outline to print on the exposed copper.  Does anyone know if this is possible without creating a new package?
Thanks.
  • dukepro
    0 dukepro over 14 years ago
    On 05/06/2012 01:56 PM, Mike Ropers wrote:
    Hello, I am wondering if there is a way to disable the silkscreen
    creating a new package? Thanks.
    Most board house (Advanced Circuits, 4pcb.com in Colorado) will mask the
    silkscreen from any area that does not have solder mask.  i.e. the board
    house will not allow silkscreen to be printed on anything other than
    solder mask.
    On all of our tight boards, I have had to place the reference designator
    (name) right smack on top of the 0603 pads simply because there wasn't
    enough real estate to place it elsewhere.  This is more than adequate
    for a process sheet or for the assembly house.
    Check with your board house.  It's a lot easier than modifying a bunch
    of library parts.
    Enjoy,
        - Chuck
    Mike Ropers wrote on Sun, 06 May 2012 13:56
    Hi Mike,
    You can't do it from the PCB editor directly.  You'll have to copy the
    device to a custom library and then edit the footprint in that custom
    library.  Finally, use the replace command to get the modified device into
    your design.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
