EAGLE User Support (English) Unconnected nets with same name
  • Subscribers 190 subscribers
  • Views 1021 views
Anonymous-105885
Anonymous-105885 over 14 years ago
I made a design in my Eagle Lite.
I have two differents pins which are not supposed to be connected. But they have same net name. So, they are short circuited in my PCB. I want to know how can this happen.
The nets(black lines) are shown in the attached figure.
    did you copy part of the net line (the arc for instance) and then used
    it to build the other net?
    Lorenz
  • dukepro
    0 dukepro over 14 years ago in reply to robotonics
    On 05/09/2012 12:13 PM, David Cotterill-Drew wrote:
    You should be using the NET  Image:image006.jpg function to connect
    pins,components...the WIRE command does nothing other than draw
    lines...
    You can name or rename NETS using the NAME  Image:image008.jpg
    function.
    And yes, all NETS with the same name are all connected together...
    The bottom line is that you'll have to rename one of the net segments.
    You can also use LABEL to label the net segments in question.
        - Chuck
  • robotonics
    0 robotonics over 14 years ago
    Hi
    Need more info, and perhaps a diagram without the back lines, it is hard to see what is going on underneath the black lines.
    You should be using the NET function to connect pins,components...the WIRE command does nothing other than draw lines...image
    You can name or rename NETS using the NAME function.image
