EAGLE User Support (English) Resistor package help
  • Subscribers 187 subscribers
  • Views 2287 views
What resistor packages would I use for a standard 1/4 and 1/2 w resistor?
    On Sun, 17 Aug 2008 19:45:34 +0200, Richard Herman
    <postbus@het-audio-team.removethis.nl> wrote:
    Ron Owens schreef:
    Jim Littlefield wrote:
    resistor?
    I assume you mean SMT? There are a lot of standard sizes.   I think
    you can get 1/4W in 0805 and up.   1/2W generally requires 1206 or
    larger.  Footprints for these parts should be in the standard library
    (rcl.lib?)  Some current sense resistors have not so standard
    footprints so you may have to create a library part.
    jiml
    For through hole parts you may have to make your own. I couldn't find
    any in the standard libraries that come with Eagle. I recommend you
    create them in the resistor library.
    All the resistors, capacitors and inductors are in the rcl.lib.
    If you make your own parts i would strongly recommend also making your
    own library file that holds such parts. That way you won't lose your
    additions after an Eagle update. you could use use the 'original' Eagle
    name and prefix this with you initials: jl_rcl.lib for instance. It's
    easier than having to make up your own library names. A seperate
    directory for those lib files ie. a subdir under 'My doucuments'
    (windows) makes it easier to backup. You can add the extra paths in the
    Control Panel > Options > Directories.
    HTH
    Richard Herman
    I ended up making my own.  It turns out that the 0207/12 package is identical to
    a 1/4 w resistor.  I guess that the Eagle code is xx yy/zz where xx is the body
    diameter (in this case, 2mm), yy is the body length (7mm in this case), and zz
    is the hole spacing for the leads (in this case 12mm).  There is an 0207/15, but
    the lead spacing is too big.
    Is this true of the other Eagle Library components?
    Steve
    resistor?
    jiml
    HTH
    Richard Herman
    I assume you mean SMT? There are a lot of standard sizes.   I think you
    can get 1/4W in 0805 and up.   1/2W generally requires 1206 or larger.
    (rcl.lib?)  Some current sense resistors have not so standard footprints
    jiml
    1/4W parts have .035" diameter holes spaced .4" apart. 1/2W resistors
    have .040" diameter holes space .6" apart. A simple box outlining the
    resistor should work for the silk screen layer.
    The Eagle help files and the Eagle tutorial are great for information on
    creating parts using the library editor.
    Ron Owens
    jiml
