EAGLE User Support (English) Version 6.2 does not function on windows 7
  • Views 255 views
When I upgraded from ver 5.11 to 6.2 the new version does not function. I kept 5.11 on the machine and it works perfectly. Click the 5.11 and it opens after a few seconds and load and edits projects. Click the 6.2 installation and it finally opens after about 2 minutes and then stalls when I try to load a project.  The direcotry setting are identical and I tried moving the project from my server to the machine that is hosting 6.2 with no improvement. Any ideas? The installation is on a Dell 620, 64 bit machine.
Bob
    Bob
    I am running 6.2 on a Win7 64 bit machine....so far without
    difficulties.   You may want to be sure that the libraries referenced in
    your 6.2 setup are the 6.2 lbrs and not the 5.11 lbrs.     From what
    others have posted it seems that 6.2 lbr format is not backward
    compatible with earlier versions.
    Jim
