EAGLE User Support (English) Copper pour overlapping even if they are of different net.
  • Views 1198 views
  • pcb
  • pour
  • clearance
  • polygon
MaxKielland
MaxKielland over 14 years ago
I have a ground plane (GND) at the bottom layer. Inside this ground plane I have an smaller analouge ground plane (AGND). When pouring the two ground planes are overlapping (connected together). They are two different netclasses and signal names so there should be a clearance distance around the AGND plane, isolating it from the GND plane.
Is this a bug or have I missed something fundamental here?
Thanks.
  • MaxKielland
    0 MaxKielland over 14 years ago in reply to e14 Contributor
    Thank you, it works fine now image
    Max Kielland wrote:
    plane.
    Thanks.
    See HELP RANK
    The inner polygon needs a smaller rank number
    HTH
    Warren
    news.cadsoft.de
