EAGLE User Support (English) polygon not completely fill, black lines...
  • Subscribers 187 subscribers
  • Views 689 views
I'm not use to post, hope i will do this wright.
I experience something strange last Friday and i'm still obsess by it today.
I use Eagle 4.16 r2
I have access to a filmstar photoplotter and a PCB fabrication facility.
I design a 1 layer PCB
This is not my fist time using this procedure, this is not my fist
project in Eagle.
I design a small PCB as always, but this time I add a polygon. this is
my first time using polygon on this process.
The polygon work fine on the Eagle software. I previously route the GND
like a signal. GND is connect to the polygon...thermal look good.
I check the gerber file in pentalogix view mate. It looks good.
I transform the file from gerber to bitmap. As always, nothing wrong here.
I start the photo plotter software, import the bitmat file, I see the
bitmap result, it ok
I start the machine with negative mirror because this is what i need for
my process.
When i develop the film i end up with a series of small black lines (~5
mil) in the polygon and the rest of the line look fine. The small line
are "cut" by the GND route i left in the board soft in Eagle. The film
is negative so clear film is the cooper and the black is etch (no cooper).
I use the negative film for my PCB. The line is so small that the etch
did not remove all cooper but i had to check to not over etch.
I have the feeling this is the way eagle in generating the polygon with
serie of black stip side by side but they are not overlaping so using
negative I end up with small black line. When i use viewmate and ask
for "trace and polygon outline only" i can see that polygon is fill with
a series of strips.
Did someone else encounter this problem? A manufacturer maybe!?
Is it a "normal" problem in Eagle?
It this resolve in 5.XX?
Do you edit gerber to solve this mater.
Thank you
    Tilmann Reh a écrit :
    Almost - when posting to more than one group, always set a follow-up-to.
    (Setting Fup2 eagle.support.eng now.)
    Yes, EAGLE fills polygons by drawing lines (of the specified "width")
    side by side. Most, of not all, CAD programs do it that way.
    They /are/ overlapping - did you forget that you checked your files
    after every conversion step you made? If the lines were not overlapping,
    you would have seen them already in the first verification (gerber
    files, or at least in the first bitmap).
    so using
    a series of strips.
    This clearly appears to me as a problem of your printer. Maybe it
    depends on the bitmap resolution - if the printer driver has to resize
    the image from your bitmap to its internal resolution, there might be
    rendering problems.
    I would try to make use of the "inverted PS" device in the CAMP. But if
    you really need to use bitmaps for this, increase their resolution to
    match or exceed that of the printer. Beware of large files, however...
    Tilmann
    Thank you for your lightning fast and full of detail respond.
    I will have to read this a few time to completely understand all the detail.
    maxime
    so using
    a series of strips.
    rendering problems.
    Tilmann
