EAGLE User Support (English) ULP syntax highlighting
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 1570 views
cosborne2000
cosborne2000 over 14 years ago
I'm just starting to learn how to create ULP's.
Is there an editor available that has syntax highlighting for the cadsoft script language?
Also, is there a way for Eagle to check for syntax errors over the full script?  (not just when it encounters them during script execution).
I've been spoiled by all the intelli-sense IDE's.
  • schusterm
    0 schusterm over 9 years ago in reply to autodeskguest
    Ahh okay, now i have it. While waiting for the eMail to finish registration at eaglecentral, i will answer here:
    Both Files (Notepad++ UserDefineLang for Cadsoft ULP v0.2.xml and userDefineLang.xml) have the same definitions. the only difference is, that userDefineLang.xml includes all definition field (also which are empty) whereas the ulp v0.2 File contains only the used fields. So it doesn't matter which file to use.
    Thank you for your help, i guess others may find this useful, too (if they can find it with a web search).
    Best regards
    MS
    0 autodeskguest over 9 years ago in reply to schusterm
    On 30/11/2016 10:47 p.m., Marius Schuster wrote:
    Hi and thank you. Even it is old, i can use it "entry point" to update this.
    https://www.element14.com/community/message/210384
    Hi
    You won't receive attachments from the forum if you use Element 14 to
    contact the Cadsoft forum. If you want a better web interface to the
    newsgroup use EagleCentral.
    Get the attached newer syntax highlight xml from my post which is
    replicated correctly on EagleCentral
    http://www.eaglecentral.ca/index.php/m/167941/3924e065ae50e87d6494d781c81a2dee/#msg_167941
    HTH
    Warren
  • schusterm
    0 autodeskguest over 9 years ago in reply to autodeskguest
    On 30/11/2016 8:32 p.m., warrenbrayshaw wrote:
    On 30/11/2016 7:54 p.m., Marius Schuster wrote:
    Location changed again!
    Where to find this usefull Laguage-Definition File now?
    Thanks and best regards
    MS
    https://www.element14.com/community/message/210350
    Try
    ftp://ftp.cadsoft.de/eagle/userfiles/misc//notepad++_userdefinedlanguage_ulp.zip
    It has a last modified date in 2010 so I suspect there may be a later
    one around elsewhere. These days I don't bother with it and simply use
    the 'C' one that comes with Notepad++
    HTH
    Warren
    Ignore the one above. Its to old and missing new commands
    Attached are a couple from my PC. Try both as I cannot decide which one
    I am using.
    HTH
    Warren
    MS
    Try
    HTH
    Warren
  • schusterm
    0 schusterm over 9 years ago in reply to swapro
    MS
  • swapro
    0 swapro over 10 years ago in reply to e14 Contributor
    The location and name of the file changed:
    EAGLE Community - PCB Tools und Konvertierer - Download & Upload
    http://www.cadsoft.de/downloads/file/notepad_userdefinedlang.zip
    It is a more recent version of the file.
    In Notepad++ v6.7.7 use the menu entry Language->Define Your Language ... ; Import. Select "Notepad++ UserDefineLang for Cadsoft ULP v0.2.xml" from the extracted zip.
    After restarting Notepad++ you'll see a new entry "Eagle ULP" close to the buttom of the Language menu.
    "cosborne2000" <noreply-65742@element14.com> a écrit dans le message de news:
    1005430911.12371338249539839.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Yes! Notepad++
    plus this XML file for ULP
    http://www.cadsoftusa.com/downloads/file/notepad++_userdefinedlanguage_ulp.zip
