EAGLE User Support (English) URL dlgAccept()
  • Subscribers 187 subscribers
  • Views 272 views
URL dlgAccept()
ameliaamelia
ameliaamelia over 14 years ago
After the discussion in http://www.element14.com/community/message/52923#52923/l/re-ulp-script-dlgaccept
I realized that when we construct a table of dlgCell, the sub element dlgAccept acts as follows:
1- if in the dlgAccept is defined a constant number, this value is saved in the dlgCell element;
2- if in the dlgAccept is defined a variable, the value of variable is not saved, but instead the pointer to the variable;
In the last case, if we use different variables all is OK, but, in my case, if we use the same variable incremented in a loop
all dlgCell return the last value in the variable.
Is that what the  Eagle wants or is a mistake?
It should be better that the dlgCell saves the contents of the variable.
Amelia.
