EAGLE User Support (English) DRILLS MISSING
  • Subscribers 178 subscribers
  • Views 1094 views
DRILLS MISSING
Hello all,
I have recently finished a small 2-sided board in Eagle 5. Now I wanted to
produce gerber and drill files to board house. I've created gerber files
with no problem but I can't create NCDRILL file correctly.
Here are settings in CAM processor:
Device: GRBDRL
Rack: File created by running drllcfg.ulp
File: Output file name.
Offset:
X: 0inch
Y: 0inch
Tolerance: 0%+0%
Style: pos. Coord, Optimize
And layers selected:44,45
After I click on process job I get the following error: DRILS MISSING - NO
DRILL FILE HAS BEEN PRODUCED!
And this is part of written *.dri file:
________________________________
Missing Drills:
-- Requested --
Size used
40.000mil 11
130.000mil 2
59.000mil 2
Drills used:
Code Size used
T01 0.700mm 21
T02 0.900mm 1
T03 1.000mm 26
T06 2.800mm 2
T07 3.200mm 4
Total number of drills: 54
!!!!!!!!! DRILLS MISSING - NO DRILL FILE HAS BEEN PRODUCED!
_______________________________________________________
And here is drl file:
T01  0.70mm
T02  0.90mm
T03  1.00mm
T04  1.02mm
T05  1.50mm
T06  2.80mm
T07  3.20mm
T08  3.30mm
I would be grateful for any assistance.
Best regards,
Maki.
    Hello all,
    Device: GRBDRL
    Offset:
    X: 0inch
    Y: 0inch
    Tolerance: 0%+0%
    Missing Drills:
    -- Requested --
    Size used
    40.000mil 11
    130.000mil 2
    59.000mil 2
    Drills used:
    Code Size used
    T01 0.700mm 21
    T02 0.900mm 1
    T03 1.000mm 26
    T06 2.800mm 2
    T07 3.200mm 4
    T01  0.70mm
    T02  0.90mm
    T03  1.00mm
    T04  1.02mm
    T05  1.50mm
    T06  2.80mm
    T07  3.20mm
    T08  3.30mm
    Best regards,
    Maki.
    It appears that two components are making this problem:
    1. F09HP from lib: con_subd
    2. B3F-31xx from lib: switch-omron
    When I delete them everything is fine, drill files are generated. I have
    noticed also when I turn on layers drills and holes, some pads that belongs
    to these components have diferent symbols (small X painted in drill layer i
    center of pad) as opposed to other components that has different symbols...
    Any workaround would be helpfull.
    Best regards,
    Maki.
  • Richard_H
    Richard_H over 17 years ago
    Maki schrieb:
    Hello all,
    Device: GRBDRL
    Offset:
    X: 0inch
    Y: 0inch
    Tolerance: 0%+0%
    Missing Drills:
    -- Requested --
    Size used
    40.000mil 11
    130.000mil 2
    59.000mil 2
    Drills used:
    Code Size used
    T01 0.700mm 21
    T02 0.900mm 1
    T03 1.000mm 26
    T06 2.800mm 2
    T07 3.200mm 4
    T01  0.70mm
    T02  0.90mm
    T03  1.00mm
    T04  1.02mm
    T05  1.50mm
    T06  2.80mm
    T07  3.20mm
    T08  3.30mm
    Best regards,
    Maki.
    Best regards,
    Maki.
    Allow tolerances of about +/- 2.5% for selecting the drills
    from the drill table. It's becasue of the conversion from inch to mm.
    Example:
    40.000 mil are 1.016mm. In the table you find 1.02mm. So you need
    a slight tolerance to find the correct tool.
    Richard Hammerl
    >> > Hello all,
    to produce gerber and drill files to board house. I've created gerber
    files with no problem but I can't create NCDRILL file correctly.
    Device: GRBDRL
    Offset:
    X: 0inch
    Y: 0inch
    Tolerance: 0%+0%
    Missing Drills:
    -- Requested --
    Size used
    40.000mil 11
    130.000mil 2
    59.000mil 2
    Drills used:
    Code Size used
    T01 0.700mm 21
    T02 0.900mm 1
    T03 1.000mm 26
    T06 2.800mm 2
    T07 3.200mm 4
    T01  0.70mm
    T02  0.90mm
    T03  1.00mm
    T04  1.02mm
    T05  1.50mm
    T06  2.80mm
    T07  3.20mm
    T08  3.30mm
    Best regards,
    Maki.
    belongs to these components have diferent symbols (small X painted in
    drill layer i center of pad) as opposed to other components that has
    Best regards,
    Maki.
    Example:
    Richard Hammerl
    Thank you Mr. Hammerl,
    Drill files generated without problems image
    Best regards,
    Maki.
