EAGLE User Support (English) SCH and BRD file names
  • Subscribers 187 subscribers
  • Views 2269 views
Can the schematic and the board file in a project have different names? The reason for asking this is that I consider the SCH file as a representation of a populated board and the BRD file basically represents the bare board, i.e. 2 different items and hence 2 different part numbers. There may even be multiple assembly options resulting in different part numbers for each board assembly variant.
For example :
Assembled board, variant 1 part number : PBA-1601-01
Assembled board, variant 2 part number : PBA-1602-01
Assembled board, variant 3 part number : PBA-1603-01
Bare board part number : PCB-2600-01 used on all the above assemblies
My ideal file names would be PBA-160X-01.sch for the schematic (X being a wildcard) and PCB-2600-01.brd for the associated board.
Is this possible with Eagle? I have to say I haven't tried it, just wanted to ask first.
Robert
1234.att1.html.zip
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:g8m94n$3qh$1@cheetah.cadsoft.de...
    For example :
    It just wouldn't make any sense. Note that schematic and board always
    share the same netlist (they are consistent and automatically annotated
    if you apply changes to one of the files). With which of your schematic
    variants should the board be consistent?
    If you don't need consistency, you can of course make (differently
    named) copies of your schematic for the different variants. There will
    be no annotation then, however.
    And, to your last question: no, EAGLE detects schematic/board file pairs
    only by their identical file names (and activates annotation only if the
    files are consistent). If you use assembly variants, always draw the
    "complete" (maximum) circuit in the schematic, and distinguish the
    variants by the BOM.
    (BTW, please don't post HTML here, and correct your line length.)
    Tilmann
    OK, I understand but I also think you misunderstood the first part of my
    question. I don't want to have multiple schematic files but just 1 file that
    comprises all the build options and from which the board is generated.
    My "problem" is more of an administrative nature. I need to document
    assembled boards as well as bare boards and obviously these must have
    different part numbers. In my example I would have 1 schematic with document
    ID = PBA-160x-01.sch containing all build options and I would make separate
    BOM's for each build option (not from within Eagle but with Excel for
    instance).
    All files (gerbers & excellon...) related to the bare board would ideally
    have the board's part number as a common file name and would be
    distinguished by their extension.
    Anyway, I'll continue using the board's part number for both schematic and
    board as I have been doing so far and make a PDF of the schematic using the
    assembled board's p/n as the file name for documentation purposes only.
    Robert
    For example :
    Tilmann
