EAGLE User Support (English) via drill size error
  • Views 300 views
homemedia
homemedia over 14 years ago
I'm using eaglecad 5.10 and have a problem on the PCB layout.
All the via's that i make give me a drill size error on layer 20 (dimension).
When i disabled the layer the problems are solved, but that is not a solution.
I dont know how i can solve this problem. The drill size is set to 'auto'.
Rik
board.zip
    Am 02.07.2012 13:52, schrieb Rik Slosse:
    Rik
    Check your DRC settings:sizes/minimum drill
    Joern Paschedag
