EAGLE User Support (English) Oups ... how do I replace the TI library?
  • Views 309 views
I'm in the process of learning Eagle PCB and apparently just happened to erase the full TI (Texas Instruments) library in Eagle (happened to click the "drop" button when placing a component). I tried to re-install the program, however, the TI library still is not there.
One of you know what can be done - I really need this library to be there .... Also, I'd like to work with an ADC which is not in the library - the ADS1675 from TI - is there a website where this information can be found?
Any help appreciated ;-)
Best regards,
Jesper
    Hi - seems I solved it - very simple actually. So no need to reply :-)
    Best regards,
    Jesper
