EAGLE User Support (English) Routing pads to the top gnd plane
  • Subscribers 180 subscribers
  • Views 368 views
  • pcb/pcb_connection
gussabina
gussabina over 13 years ago
Hi: I'm designing a 2-layer pcb, and mostly for SMD devices, so most of the pads are on the top layer. I created two gnd planes (top and bottom), and when I want to route those pads connected to gnd, I can easily connect to the bottom gnd plane using a via, but it should be easier to connect to the top gnd plane so I can avoid the via... I can't find a way to route those pads to the top gnd layer...What I'm missing?
Thanks in advance
Gus
    0 Former Member over 13 years ago
    Thanks in advance
    Gus
    Perhaps your top ground plane does not have the correct net name?
    Jim
  • gussabina
    0 gussabina over 13 years ago in reply to Former Member
    Hi Jim:
    I don't know how but this was what happened. The plane did not have the correct name, even when I did it (may be, I named bottom gnd layer twice...)
    Gus
    0 Former Member over 13 years ago in reply to gussabina
    On 7/27/2012 11:40 AM, Gus Sabina wrote:
    Hi Jim:
    Gus
    Sound like you are all set then...
    Cheers,
    Jim
