EAGLE User Support (English) Help with missing Junction Warning
  • Subscribers 191 subscribers
  • Views 1102 views
scott216
scott216 over 14 years ago
I'm new to Eagle.  When I click the Errors button, I get a bunch of Missing Junction warnings, but everything looks fine to me.  If I move a component around, the wires attached to it move with it.  For some of the errors, Eagle's error pointer is pointing to empty space.  What do I do about this?  Please see attached screenshot.
  • scott216
    0 scott216 over 14 years ago in reply to e14 Contributor
    If I still have an error that I haven't fixed yet, does this clear that error?  I want legitimate errors to still show up and just stuff that I fixed to go away.
  • dukepro
    0 dukepro over 14 years ago in reply to e14 Contributor
    On 08/06/2012 02:29 PM, Jorge Garcia wrote:
    On 8/5/2012 10:45 AM, scott216 wrote:
    >> I just closed and re-opened Eagle and a bunch of the warning went
    >> away, so Eagle must be doing some kind of refresh when I do this.  How
    >> can do I get Eagle to refresh the errors and warnings without opening
    >> and closing the application.  Is that what the Processed button is for?
    Easiest way to clear the errors and warnings in EAGLE is to click the
    icon with the black exclamation point inside a yellow circle. This will
    pop up the errors in your design.
    Click the clear all button.
    You can also do a "errors clear" from the command line.  See HELP CLEAR.
        - Chuck
    0 e14 Contributor over 14 years ago in reply to scott216
    I just closed and re-opened Eagle and a bunch of the warning went away, so Eagle must be doing some kind of refresh when I do this.  How can do I get Eagle to refresh the errors and warnings without opening and closing the application.  Is that what the Processed button is for?
    hth,
    Jorge Garcia
  • Nate1616
    0 Nate1616 over 14 years ago in reply to scott216
    Im not sure if this will work and probably isnt the best way but try to update the library.  this should make eagle refresh.  There might even be a view/refresh button in the control panel.
  • scott216
