EAGLE User Support (English) How to generate RS-274X G36/G37 outline fills?
  • Replies 9 replies
  • Views 1707 views
I would like to draw a complex vector logo on the silkscreen of my boards. I would like it to be output as an RS-274X Outline Fill, with the commands G36 and G37.
I've tried drawing the logo (through a script) using the Polygon command on the tPlace layer. But when exporting the silkscreen with a custom CAM job using the GERBER_RS274X device, it seems that the polygon is stroke filled.
I may have missed something. Is there a polygon property, a CAM job option, or any other way to have my complex polygon exported as a proper G36/G37 Outline Fill?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    B Mac <noreply-127215@element14.com> wrote:
    I just wanted to chime in here. Polygon support in the CAM jobs (aka G36
    + G37 gerber commands) would be VERY nice. I don't believe it is very
    hard to impliment either. Eagle can still KEEP the "width" property...
    all they have to do is draw the outline as a stroke with width (which is
    currently already done), followed by the G36 + G37 commands of the EXACT
    SAME co-ordinates! We tried manually editing our gerbers and this works
    amazingly. Also, the board houses are much happier when solid fills are done properly.
    +++++1 for this feature. I swear, it is easy to add!
    Crossing fingers...
    As I mentioned, since I dont know gerber very well, I could not find out
    how to handle clear areas inside the fill. If anyone knows, please let me
    know.
    I just wanted to chime in here. Polygon support in the CAM jobs (aka G36 + G37 gerber commands) would be VERY nice. I don't believe it is very hard to impliment either. Eagle can still KEEP the "width" property... all they have to do is draw the outline as a stroke with width (which is currently already done), followed by the G36 + G37 commands of the EXACT SAME co-ordinates! We tried manually editing our gerbers and this works amazingly. Also, the board houses are much happier when solid fills are done properly.
    Crossing fingers...
    >I can't see a link to the file (I'm using the element14.com forums to see
    >this conversation). Did you forget to attach it or did it get lost somehow?
    This is another element14 problem. The attachment is visible from direct
    nntp access or Eaglecentral here:
    http://www.eaglecentral.ca/forums/index.php?t=msg&th=47080
    I can't see a link to the file (I'm using the element14.com forums to see this conversation). Did you forget to attach it or did it get lost somehow?
    >Can you share that script? I'm very interested by such a tool, but it seems
    >to represent a lot of work so I'd rather not start from scratch.
    I attach it here.. I do not take any responsibility if it fails with your
    design.
    IMPORTANT:Run RATSNEST before running it! Orelse the polygon fills won't
    show up.
    Doc is undone, but the general usage is:
    run gerber-RS274x -L];
    Options can be any order.
    For output filename you may use  %N in the string to be replaced with
    boardname.
    fillmode:
    e for eagle fill (default)
    f for flash gerber fill (only works on polygons with no negative contours or
    arcs or width!=0, in other words not many. NOT TESTED AT ALL!)
    The gerber output will also contain some gerber comments.
    Also, this is not tested on Ealge 6.
    Feel free to clean it up and improve.
    Example:
    Here I add my patch layer 53 to top and output as myboard_L1.gbr
    run gerber-RS274x -L1,53 -o%N_L1.gbr -dTopLayer;
    Guest wrote:
    Jérôme Vuarand <noreply-119775@element14.com> wrote:
    How did you write such an exporter? Can you add your own CAM drivers to EAGLE?
    Its done with an ULP, not the cam. An ULP have direct access to most
    parameters. I did this because the manufacturer of a HDI board wanted all
    pads to be flashed. I guess it enables better HDI-DRC.
    Can you share that script? I'm very interested by such a tool, but it seems to represent a lot of work so I'd rather not start from scratch.
    I once made my own
    > gerber export to get smd's to be flashed instead of being
    > drawn, and I tried to use the gerber fill for polygons, but my gerber
    > knowledge was and is rather limited, so I could not resolve how to make gaps
    > (negative fill) in the polygons. Let me know if you know how to do that.
    I once made my own gerber export to get smd's to be flashed instead of being
    >G36 and G37.
    >Outline Fill?
    Afaik, Eagle does not support this. Eagle fills all its polygon with wire
    with width set in the polygon attributes before exporting to gerber. This is
    a drawback when working with huge complex boards, as it slows down eagle a
    bit.
    It would be nice if a future version could do this for example when polygon
    width is set to 0. It would make screen drawing faster too.
