EAGLE User Support (English) Library for 6-pin on-off switch(dpst)
  • Replies 11 replies
  • Subscribers 192 subscribers
  • Views 4914 views
  • eagle
  • library
  • schematic
I got a 6-pin on-off switch (image shown) for which i am not able to get proper library in eagle because i dont know the manufacturer. Please help me with the schematic too.image
    0 shabaz over 6 years ago in reply to rel2009
    It's a five-minute job to create this (if working really slowly).. I'm not going to supply it, because then you're not learning anything for when you need the next part.. You'll be self-sufficient if you spend 20 minutes learning how to do it.
    It may not be the answer you want, but it's what you need to solve all future similar problems.
    Here's the blog post and video explaining how to do it: EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
    Here's what it may look like (this is the TL4201 variant):
  • rel2009
    0 rel2009 over 6 years ago in reply to fritzz
    Is it possible to find the TL2203 library? I know its been a few years but could someone email it to me? The suggestion below of the 9077 is to large at 10x10mm and this part is 7x7mm. thanks
  • bluetang2
    0 bluetang2 over 8 years ago
    Try switch-misc library: 90772 MARQUARDT SWITCH 9077.0200.
    0 e14 Contributor over 14 years ago in reply to fritzz
    Ok. You can e-mail me the library.
  • fritzz
    0 fritzz over 14 years ago in reply to e14 Contributor
    I dont want to put it here for eternity as I am not 100% sure it is good.
    (Untested, so you can review before you use.)
    Thank You again. Could you please attach the file to this forum?
  • fritzz
    I just made a TL2203 footprint, but how to get it to you?
    0 e14 Contributor over 14 years ago in reply to robotonics
    Thank You, the closest is E-switch TL-2203 (based on dimensions and pin connections). The datasheet is at http://www.e-switch.com/Portals/0/Series_Pdf/TL2201.pdf.
    Right its DPDT,sorry for wrong info.
  • robotonics
    0 robotonics over 14 years ago in reply to fritzz
    Or maybe a TL-2230 ? Datasheet here for both...
  • fritzz
    Looks like an E-Switch 2285. Is it 8mm square?
    I had to make the part.
    (It's a DPDT, not DPST)
