EAGLE User Support (English) Selective printing
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 708 views
Selective printing
I have been asked if I can print out the silk screen with only the test points visible.  The PCB has many parts and over 50 TPs. They would like to be able to just see the TPs so they can find them quickly while testing. Been using Eagle for a long time and have never been asked this one before. Any ideas?
    0 e14 Contributor over 13 years ago in reply to dukepro
    Chuck, Thanx. I will lok into that.
  • dukepro
    0 dukepro over 13 years ago
    Take a look at panelize.ulp.  The salient feature I would like to point
    out is that it copies all the texts on tnames to layer 125, and all the
    texts on bnames to layer 126.  You could extract this segment of code to
    filter out only TP elements, and copy the name of just those elements to
    a user defined layer and display just that layer.  Your code could also
    add a square that overlays the SMD pad to that same layer.
    Additionally, you can create two user-defined layers and have all your
    bottom test points on one layer, and all your top test points on another.
    The bottom line is that it is possible, but may take a hour of ULP
    programming to accomplish.
    Look around line 93 in panelize.ulp (as distributed with 6.2) which
    collects names, and the Text function at line 65 that prints the names
    on the same layer number plus and offset of 100.  Thus names on layer 25
    are copied to layer 125, and names on layer 26 are copied to layer 126.
    HTH,
        - Chuck
    On 9/20/2012 11:44 AM, Robert Thomas wrote:
    Doug,
          Another good idea, but >NAME doesn't seem to work on anything but the names layers, oh well.
    It works perfectly for me.
    I use/misuse the variables a lot.
    Doug,
    On 9/20/2012 10:45 AM, Robert Thomas wrote:
    Doug,
          That is a good idea, but only gets me half way there. I can put an outline of the pad on an unsed layer but the names that reside on the names layer are still all or nothing.
    Can you add the variable >NAMES to the library part on the new layer?
    Doug,
    You could modify the library part to add what you need to another layer
    and you could turn on that layer and whatever else you need to print for
    that.
    -D
