EAGLE User Support (English) Carry global attribute across schematic and board?
  • Subscribers 189 subscribers
  • Views 867 views
  • board
  • attributes
  • schematic
Is there a way for both the schematic and board to share or access a global attribute? I use a global attribute to put revision information into the schematic sheets and the silkscreen of the board but have to remember to up-rev them both seperately, which doesn't always happen.....
  • dukepro
    0 dukepro over 13 years ago in reply to e14 Contributor
    On 09/27/2012 02:36 PM, Eric Deuel wrote:
    Workaround provided here ... http://www.element14.com/community/thread/16084 (/thread/16084)
    This was posted in the eagle.suggest.eng forum.  Search for "Project
    level attributes".  The first post was on 20-Jul-2011.  I'm using NNTP
    so I don't have a thread identifier to reference.
    You might be able to fiddle with the package associated with a frame by
    placing the text on the tNames layer.  With that, you may be able to
    smash the part in the board editor and change the size/ratio/font etc there.
    The down side to adding a package to a frame is introduced when you have
    multiple sheets.  It may be better just to create a separate device
    complete with a symbol and a package.
    HTH,
        - Chuck
