EAGLE User Support (English) Drill file weirdness
  • Views 475 views
I tried to use drillegend-stack.ulp to add a nice drill legend to my fabrication drawing.
Now when I run the standard Excellon CAM job, it splts the drd file into two sections.
=> drd.0102
=> drd.0116
I have tried to go backwards by deleting the layers inserted by the ULP, but cannot restore my project to the working state before I tried to add the drill legend.
How does the CAM job decide to split the drill file and what file do I access to fix the file corruption caused by the ulp ?
    Thanks Jorge,
    That did the trick. I had fat fingered layer setup. I will add that to my list of "things that can do wrong"
    => drd.0102
    => drd.0116
    Hi Matt,
    The ULP isn't the cause of the corruption here. What's going on here is
    that you don't have your layers setup properly in your board. Judging
    from the output you currently have blind vias setup from layers 1 to 2
    and through hole vias from layer 1-16. That's why there are two seperate
    drill files.
    If you intended to have blind vias from layer 1 to 2 then this output is
    correct. If you did not intend to have blind vias then you need to
    correct your layer setup by going into the DRC -> Layers tab.
    Let me know if you need any further clarification.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
