EAGLE User Support (English) Ripup = Delete?
  • Subscribers 177 subscribers
  • Views 182 views
Ripup = Delete?
Eagle 5.2.0 Professional
When ripping up traces in the board editor, if you hit ripup too many times
it deletes the airwire also (or at least I can't see it anymore). After
routing I still can't see this connection being made. How do I get the wire
back?
I have tried to delete the component in the scematic and replace, but it
still leaves the component with one displayed connection. ERC and does not
complain about unconnected pins though.
TIA.
Eldon.
    On Thu, 4 Sep 2008 10:02:11 -0500, "Eldon Hiebert"
    back?...
    I could not duplicate that behavior.  When I ripup a trace, it
    replaces that trace with an airwire.  If I ripup an airwire, it rips
    up other traces in the same net, but still leaves an airwire.  The
    only time I have ever seen an airwire totally disappear with ripup is
    if I have ripped up a redundant connection (such as often happens with
    ground or power).  Then the remaining airwires will be the minimum
    needed to connect all the points in a given net.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
