EAGLE User Support (English) Upgrade from 6.2 to 6.3
  • Subscribers 190 subscribers
  • Views 437 views
scroggyg
scroggyg over 13 years ago
I have this morning upgraded on my MAC from 6.2 to 6.3. It is now asking for a new license file.
Is this correct?
    0 e14 Contributor over 13 years ago in reply to dukepro
    On 11.10.2012 14:55, Chuck Huber wrote:
    On 10/11/2012 05:54 AM, George Redpath wrote:
    >> I have an installation Code, and a Eagle.key file, but I can't find a license file, where would that be stored?
    The Eagle.key file /is/ the license file.  Enter the full path to that,
    then in the bottom text box, enter the installation code.
         - Chuck
    That's not correct. eagle.key will be generated when you license your
    EAGLE. For this you need the installation code that consists of 10
    lower case letters and the license file which is usually named
    'serialnumber'.key.
    Richard Hammerl
  • dukepro
    0 dukepro over 13 years ago in reply to scroggyg
        - Chuck
    5700.att1.html.zip
  • scroggyg
    0 scroggyg over 13 years ago in reply to e14 Contributor
    George
    Is this correct?
    Hi George,
    This is correct, every time you update EAGLE you have to license it as
    if you had never had EAGLE on your machine. You use the same license
    file and installation code you used the first time.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
