EAGLE User Support (English) How do I handle multiple schematics with one board file in Eagle?
  • Subscribers 187 subscribers
  • Views 2461 views
  • eagle
  • sch
  • schematic
I use the hobby version of Eagle where you can use multiple schematics.
I want to have several schematics (.sch) files and only one (.brd) file.
power.sch
mounthole.sch
button.sch
mcu.sch
analog.sch
And these should be linked to a pcb file called gadget.brd
When I start the first step by creating the mounthole.sch and want that to transfer to my gadget.brd file Eagle create a new .brd file called mounthole.brd.
I have found several tutorials on how to use Eagle with a single schematic and a single board file but none on how to use multiple .sch files.
Is there any one here that can recomend a tutorial on this?
Is there any one here that can give me advice on how to do this?
Regards
CreoNic
    On Fri, 19 Oct 2012 21:15:29 +0000, Niklas Wennerstrand wrote:
    power.sch mounthole.sch button.sch mcu.sch analog.sch
    mounthole.brd.
    files.
    Regards CreoNic
    Are you trying to have five boards all on one panel?
    Or are you trying to make a five-sheet schematic for one board?
    If you're trying to make a multiple-sheet schematic, just use multiple
    sheets!
    Tim Wescott
    Control system and signal processing consulting
    www.wescottdesign.com
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Yes this work.
    Thanks.
    Info for other users:
    When a schematic is open you have a dropdown box at the top of the schematic saying [1/1]
    There you can add another schematic (by selecting "new") and then the box will say [1/2].
    On 10/19/2012 2:15 PM, Niklas Wennerstrand wrote:
    power.sch
    mounthole.sch
    button.sch
    mcu.sch
    analog.sch
    Regards
    CreoNic
    Hi Niklas,
    I would put the schematics on separate sheets in a single schematic.
    Then they are all separate and linked to one board.
    Would this work for you?
    -D
