EAGLE User Support (English) understanding part numbers and packages
  • Subscribers 178 subscribers
  • Views 2100 views
I'm very new user of Eagle and I'm trying to understand how to use the
right parts. For example, I'm using a 10K carbon film resistor 1/4 watt
5% tolerance.  I see in resistor.lbr  under  R-US_ RESISTOR- American
symbol package 207/12   (type 207 grid 12mm).  Where exactly do I find
these package numbers?  How do I match my part to a part in the library?
Here's the data sheet the I'm using
http://www.mouser.com/catalog/specsheets/XC-600035.pdf
What part should I use?
    "Mark" <bob@nospam.net> wrote in message news:gack7g$9rp$1@cheetah.cadsoft.de...
    I'm very new user of Eagle and I'm trying to understand how to use the right parts. For example, I'm using a 10K carbon film
    resistor 1/4 watt 5% tolerance.  I see in resistor.lbr  under  R-US_ RESISTOR- American symbol package 207/12   (type 207 grid
    12mm).  Where exactly do I find these package numbers?  How do I match my part to a part in the library?
    You don't need to worry about tolerance, eagle is not a simulator so it dosn't matter.
    According to the datasheet your resistor is 6.8mm wide, so you might use 207/10 as
    207/7 is just 7.5mm apart so it'll be a tight squeeze (and you shouldn't bend the wires
    that close to the package - use at last a couple of mm's from the package edge).
    And what does type 207 mean? I know it a package but I don't see 207 in
    the data sheet.  What does types 204, 207, 309, 411 mean?
    I noticed for  Power Metal Film Resistors in
    http://www.vishay.com/docs/28729/pr010203.pdf
    "High power in small packages (1 W/0207 size to
    3 W/0617 size)"
    So 207 is the diameter size?
    (I'm a EE but it's my first time making a schematic to PCB.)
    SNIP
    3 W/0617 size)"
    It is the diameter and size of the resistor body in centimeters.
    So the 1. value in your example means 1 Watt and body size 2x7
    Milimeters = 0,2x0,7 Centimeters. Forget the x and commas and you have 0207.
    (Like you write 2k7 for a resistor value of 2.7 kilo ohms).
    The 3 Watts resistor has a body of 6x17 milli- or 0,6x1,7 centimeters.
    Since it is not really healthy for a resistor to bend the wires sharp at
    the body you leave a milimeter or two before you bend them as seen at
    page 4 of your pdf-file. So this leads to the "/value".
    If you check the eagle rcl.lbr pick a resistor 0207/7 and a 207/15 and
    place them in the schematic. They look alike but if you switch to brd
    you will notice the differece. The bodies are equal but the wires have a
    different length. So the value behind the / is the grid size of the part.
    Gruß
    Jörn
    Former Member over 17 years ago
    Try this
    http://www1.schukat.com/schukat/schukat_cms_en.nsf/index/CMSDF15D356B046D53BC1256D550038A9E0?OpenDocument&wg=C1120&refDoc=CMSEDB0DE6075308E5CC1256D710034AC23
    "Mark" <bob@nospam.net> schrieb im Newsbeitrag
    right parts. For example, I'm using a 10K carbon film resistor 1/4 watt 5%
    package 207/12   (type 207 grid 12mm).  Where exactly do I find these
