EAGLE User Support (English) eagle about library
  • Views 556 views
eagle about library
Hello,everyone
      I am using EAGLE, but some questions appear.so I need some help,thank you.
      how to run the copy button to copy a package from board to library?
      add:My EAGLE version is 6.1.0
from ellen
Best regards
    Excellent!
    -D
    Hello,Doug
           I have run the suggestion you gave,it succeed.Thank you.
    Best wishes!
    yes,in fact I don't have the library the part exists.I can copy it from one library to another if I have the library.It's easy.so ,running the ulp what you said ,how to run?thanks.
    Best regards.
    On 11/14/2012 5:51 PM, ellen du wrote:
    nobody knows?:-/
    To copy a part from a board to a library you could run
    exp-project-lbr.ulp. I am assuming that you do not already have the
    library the part came from. Otherwise you would copy from that.
    nobody knows?image
