EAGLE User Support (English) Changing between board and schematic
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 2668 views
  • shortcuts
Hi!
I am using EAGLE 5.11 and I was wondering if I can create a shortcut to change between schematic and board and vice versa. I already found the command "Board" which does the trick if I am in the schematic, but I could not figure out what command should I use to change from board to schematic. I did some googling as well, but unfortunately I could not find the answer.
Any input is appreciated.
Cheers!
    0 e14 Contributor over 13 years ago in reply to Morosh
    Maurice SAAB wrote:
    >On 26/11/2012 08:51, Lorenz wrote:
    >> Maurice SAAB wrote:
    >>> Simpler version, without creating script file at all.
    >> No ULP / script needed at all.
    >> You can just assign
    >>      "edit .sch"
    >> to a key in the schematic and
    >>      "edit .bar"
    >> in the board editor.
    >Good to know that, but you should have two assigns for switching, No??
    there are separate  key assignments for each editor (schematic, board,
    library).
    Therefore you are free to assign the same key in schematic and board
    editor.
    Lorenz
  • Morosh
    0 Morosh over 13 years ago in reply to e14 Contributor
    You can just assign
         "edit .sch"
         "edit .bar"
    You can just assign
         "edit .sch"
         "edit .bar"
    Lorenz
  • Morosh
    Hi!
    Cheers!
    THT
    toggle_brd_sch2.ulp.zip
  • Morosh
    Hi!
    Cheers!
    try the attached ulp, you can add in your startup file eagle.scr:
    assign Alt+T run toggle_brd_sch;
    if you want to have Alt+T as a shortcut.
    HTH
    Maurice
    toggle_brd_sch.ulp.zip
    This is bit off topic, but I warmly recommend second monitor. Personally
    running with three monitors now, one for schematic, one for board and
    one for datasheet/web browser.
    Thank you! I could not find this, but maybe I was just looking in the wrong direction. I was trying to find a command which will open the other window to map it to a key, but this is almost as good!
    Alt-1 and Alt-2 (etc.) simply and fast switch between the different
    editor windows (look at their numbers in the title bars).
    (See Manual, "function keys".)
    Tilmann
    see "help edit"
         "edit .sch"  switches to schematic
         "edit .bar" switches to board
    the board command is normaly used to create a .brd file if non exists
    yet.
    Lorenz
    Zoltan Redey <noreply-144560@element14.com> wrote:
    Hi!
    the answer.
    Klick on the ICON left to the page selection box in the schematic and
    identify the same icon in the board and click that.
    Bye
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
