EAGLE User Support (English) Import CADSTAR PCB v13.0 working files into Eagle v5.1
  • Subscribers 189 subscribers
  • Views 1170 views
  • eagle_software_cadstar_convert
I'm working on a project that has legacy CADSTAR PCB v13.0 files and client is requesting changing of the methodolugy which means usage of Eagle v5.1. Is there any posibility of direct importing of the working files into CadSof Eagle v5.1?
If not, could you please advise which is the easiest way, or refer me to some sources where I can learn about.
Your answers are appriciated.
Lj.
  • MattyLad
    0 MattyLad over 13 years ago
    Hi, CADSTAR 13 is not legacy, its the current version.
    Why do they wanto downgrade to Eagle?
    (And it is a downgrade).
    If they have CADSTAR13 then they would need to output archive files for the conversion process.
    It won't be cheap.
    What sort of design is it? (technology/layers etc?)
    These people provide an option but at a cost
    http://www.logicswap.com/catalogue.php?id_cat=54
