EAGLE User Support (English) Eagle.scr - linux
  • Subscribers 178 subscribers
  • Views 462 views
Eagle.scr - linux
Hi All,
I've created a simple eagle.scr file:
USE -* $HOME/eagle/libs/*;
BRD:
grid mm 0.5 on;
set width_menu 0.2 0.3 0.4 0.5 0.6 0.8 1.0 1.5 2.0;
change width 0.4;
change shape round;
However, the script does not get automatically run when I open a
schematic of board. If I put the same commands in the system eagle.src
file, everything works fine.
My file is located here:
/home/ajg112/eagle/scr/eagle.scr
In the Directories dialog, I've set 'Scripts' to
$EAGLEDIR/scr:$HOME/eagle/scr/
Any suggestions?
EAGLE, Version 5.2.2 for Linux, Professional Edition
Andy
  • Richard_H
    Richard_H over 17 years ago
    Andy schrieb:
    Hi All,
    BRD:
    grid mm 0.5 on;
    change width 0.4;
    change shape round;
    Any suggestions?
    Andy
    The path $HOME/eagle/scr/ must be the first one. It will be
    executed then.
    Richard Hammerl
    executed then.
    That did it.
    Many thanks Richard
    Andy
