EAGLE User Support (English) ULP How check if file exists or not
  • Subscribers 189 subscribers
  • Views 1077 views
  • eagle
  • ulp
  • cad
jltharin
jltharin over 13 years ago
Hi everybody,
How can I check in my ULP if a file exist or not?
Thanks in advance for your answers!
Jean-Louis
  • jltharin
    0 jltharin over 13 years ago in reply to e14 Contributor
    Like this you have a problem of syntax of string
    This is a C style language, hence you have to write:
    x = FileExists("C:
    test.txt");
    The Solution is:
    int x;
    string etxt;
    int FileExists( string name )
         string files[];
         return (fileglob(files, name) != 0);
    x = FileExists("C:/test.txt");
    sprintf(etxt,"%d",x);
    dlgMessageBox(etxt);
    I need to use a "slash" and not a "back slash"!
    Thanks to you for your help!
    0 e14 Contributor over 13 years ago in reply to jltharin
    Am 30.11.2012 12:16, schrieb Jean-Louis Tharin:
    x = FileExists("C:\test.txt");
    x = FileExists("C:
    test.txt");
  • jltharin
    I try this:
    int x;
    string etxt;
         string files[];
    My problem is that x is always 0 that file exists or not.
    Do you have an idea?
    try something like this:
    int FileExists(string name)
         string files[];
    Rene
