Does anyone have or know where I can find a part file for a standard 3mm superflux 4 pin LED? Seems to be such a simple part that there would be one around somewhere..
On 04. des. 2012 18:06, Mark Sawyer wrote:
Thank you but you're misunderstanding me..
I don't need the data sheet.. what I'm looking for is the actual part file so that I can place it in the schematic and board diagrams. I shouldn't have to create the part from scratch as it's a fairly common item. I'm sure that somewhere out there, there is a .lbr file that will help.
I guess its not there, so you would save some time making it your self.
Its fun also to create such library creatures by your own
The data sheet gives all the dimension you need, and the symbol, i.e.
the DIODE shape to use in the schematic, you may steal from some other lib.
Breg
Vidar (Z)
If you do a search for that part # on newarks home page www.newark.com in the part search tool you will see a blue link for the data sheet
Yes, that's the one. I don't see a part file listed for it though?
I believe that is Newark stock # 52K5239
Also, am I to assume that the existing part file for the "SUPERFLUX-7.6X7.6" is really the standard 5mm 4 pin superflux LED?
