EAGLE User Support (English) miter command?
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 2419 views
miter command?
fritzz
fritzz over 13 years ago
When I use the miter command it always defaults to the rounded corners, and I have to switch to angled. I can't find any documentation on how to change that.
Can anyone help?
  • fritzz
    0 fritzz over 13 years ago in reply to AnalogNotes
    Thanks. It makes sense now.
  • AnalogNotes
    0 AnalogNotes over 13 years ago in reply to fritzz
    It will switch back and forth depending upon what you have your grid set to.
    Doug
  • fritzz
    0 fritzz over 13 years ago in reply to e14 Contributor
    Do you just mean mils if set to imperial and mm if set to mm, or the actual grid view detail?
    (Not a a machine to test)
    0 e14 Contributor over 13 years ago in reply to fritzz
    d r wrote:
    >Perfect. I didn't see what the numbers related to, but now I see it's mils.
    depends on the grid setting
    Lorenz
  • fritzz
    Very much appreciated.
  • AnalogNotes
    From the help:
    Straight versus round mitering
    If radius is positive, the inserted wire will be an arc with the given radius; if it is negative, a straight wire will be inserted (imagine the '-' sign as indicating "straight"). You can toggle between round and straight mitering by pressing the right mouse button.
    So, for example, if I type:
    miter 25
    I end up with a round corner, and if I type:
    miter -25
    I end up with a straight one...
    Try putting the "miter -25" (or whatever your preferred radius is) in your eagle.scr and see how that works for you...
    Doug
  • fritzz
    I have looked at HELP MITER, but it doesn't seem to cover that.
    It's pretty vague!
  • AnalogNotes
    Check out the miter help under editor commands in the help system.  You should be able to put the command in your eagle.scr file (open "Scripts" in the Control Panel) and it will always go into effect when you open up EAGLE...
    Doug
