EAGLE User Support (English) Eagle 6.3 crashing under Win7
  • Views 299 views
mouradnik
mouradnik over 13 years ago
Updated to E6.3.0 yesterday from E5.11.0
Starting with a brand new project.
Endless crashes that seem to have no relation to the action in process.  Never saw a crash with 5.11.0
I have not run more than 15 minutes without seeing the Eagle.exe has stopped working dialog.
I have checked permissions on the program directory.
The only old thing I have seen is that when I create a new project the new eagle.epf file still points to many of the old 5.11 libraries.
I have manually deleted the "UsedDirectory=" lines that point to the 5.11 libraries and I'm still getting the crash and burn.
The Options | Directories entry is set to "EagleDir\lbr" per the default setting.
Thoughts?
Mike
    Thoughts?
    Mike
    Hi Mike,
         There may be a conflict due to the eaglerc.usr being shared between
    your old V5 and your new V6. Try the following:
    1.Open a text editor(Notepad, Notepad++, etc.)
    2.You're going to write a very simple batch file, its a one liner that
    consists of:
    'fullpath_to_the_eagle_executable_here'
    -U'Path_to_where_you_want_eagle_to_store_eaglerc.usr'
    3.Save this to your desktop with whatever name you find convenient the
    extension needs to be .bat.
    4.From now on double click it to start EAGLE. This will make sure EAGLE
    uses a seperate eaglerc file and you will no longer have interactions
    with V5.
    hth,
    Jorge Garcia
