EAGLE User Support (English) Accidentally removed a component from Eagle
  • Views 978 views
Im new to Eagle and still finding my feet. I want to create a PCB that uses a 100 pin TQFP device. I went to edit/add and searched for the device. I found it, but accidentally pressed DROP instead of OK, now its no longer there, how do I replace it? I even tried re-installing Eagle but its still not visible.
Many thanks.
    Many thanks.
    For a library to be available via the add command (selectable) you need to
    make it avaible with the USE it.
    DROP unfortunatley means un-USE
    To get all your libraries back there are a number of ways
    Enter enter into the command line USE *
    That will make all libraries on your library paths available. Can take a
    while on a slow machine.
    and choose the library to open
    You could look in the Control Panel, find the library of interest and click
    the Grey dot beside it  and make it Green
    See USE in the help for more info
    HTH
    Warren
    news.cadsoft.de
