EAGLE User Support (English) Using nets on Eagle
  • Subscribers 189 subscribers
  • Views 479 views
Using nets on Eagle
Hey guys, I'm having problems when organizing components with nets on Eagle.
Here's my schematics. I'm building a arduino with a zif for the atmega, a rf receiver module,
a button, a relay and a switch.
Okay, the problem is, that. When I pass the schematics to Board
everything get's messed up. Or when I use the Autoroute command,
how can I autoroute it so there's only the top layer? (mainly because I only know how to print in the top layer)
Well, after autorouting, everything gets more messed up
So I wanted to make it more organized making two more trails - one for vcc and one for gnd.
How can I do that? Do you guys have any tips or tricks for me? I started using Eagle this week.
Thanks in advance,
Gabriel
    Eagle.
          • Please be specific when asking for assistance. What do you mean by
    "everything get's messed up"?
    It is normal for all the components to be there in a group when you craete a
    board from a schematic.  You need to place them where you wish within a
    board outline.
    Then obsereve the airwires. These equate to the nets on the schematic These
    you turn into traces with  the ROUTE command or , if you must, the
    autorouter.
        • Your design shows through hole components so I suggest you create a
    bottom layer if your are going to etch and drill  a single sided board
    yourself.
        • Again, "messed up"???
    The autorouter takes quite a bit of understanding. It's not magical. Read
    the manual.
    Read the manual and tutorial in the docs folder of your installation.
    Find tutorials on the web. There are plenty of YouTube videos
    Eagle will frustrate you if you don't
    All the best
    Warren
    news.cadsoft.de
  • fritzz
    0 fritzz over 13 years ago
    In the autoroute setttings, if you shut off layer 16. it only will route layer 1, the top.
