EAGLE User Support (English) Domepad eagle lib part
  • Views 574 views
  • domepad
  • dome_pad
  • library_part
The image above is a so called "domepad", a landing pattern for a button.
But does anybody know how to make this correct in a eagle library element?
The inner part and outside line should be functioning as different pin's.
The problem is that i have to draw with copper to get this shape, else i need to use many different pads.
But this way i get endless DRC errors like clearance and overlap.
And i need to choose a central point (The physical pad for in library) where the connection is made.
Does anybody know how to make a element where i have 2 connection points in the schematic and a DRC free footprint?
Thanks in advance,
Bram van Herck
    Bram Herck, van wrote:
    Hi Warren,
    Thanks for the quick relpy.
    I'm going to dive into the library and attempt to make my own correct
    one.
    Bram
    You're welcome.
    Note that that library did not address the  tStop and tCream layers.
    You should turn off the cream for the SMD pads and make a area that should
    be clear of solder stop with a shape on the tStop layer
    Warren
    news.cadsoft.de
    Hi Warren,
    I'm going to dive into the library and attempt to make my own correct one.
    Bram
    Warren Brayshaw wrote:
    Have a read of the manual Section 8.14 Arbitrary Pad shapes.
    The manual is in the docs folder of your installation. This will give
    you an understanding of the requirments for arbitrary pads.
    Attached is a rough library of what you are asking for. Revese
    engineer it to understand how its done especially CONNECT where each
    pin is connected to many pads. The first pin pad connection is made
    with the CONNECT button and subsequent ones made with the APPEND
    button.
    HTH
    Warren
    Web access to CadSoft support forums at www.eaglecentral.ca.  Where
    the CadSoft EAGLE community meets.
    The attachment reached the Cadsoft News Group correctly but not Element14.
    Will that ever be fixed? Drew??
    File is at Eagle Central but it has a problem there. It picked up an
    additional extension (.htm)  filename.lbr.htm so watch out for and remove
    the additional .htm
    http://www.eaglecentral.ca/forums/index.php/m/148806/09b2cb136ce5b922484789d309009220/#msg_148806
    Warren
    news.cadsoft.de
    The manual is in the docs folder of your installation. This will give you
    Attached is a rough library of what you are asking for. Revese engineer it
    to understand how its done especially CONNECT where each pin is connected
    to many pads. The first pin pad connection is made with the CONNECT button
    and subsequent ones made with the APPEND button.
    HTH
    Warren
